/[Development]
ViewVC logotype
Revision 4147
Jump to revision: Previous Next
Author: hailfinger
Date: Tue Apr 21 00:16:06 2009 UTC (4 years, 1 month ago)
Changed paths: 87
Log Message:
Thanks to Myles' patch adding support for include statements,
refactoring Config.lb became possible.
Factor out ROM size calculation from Config.lb.
This patch converts 87 boards (with and without USE_FAILOVER_IMAGE),
but it has to work around a parser bug.
89 files changed, 209 insertions(+), 2415 deletions(-)
A total of 2206 removed lines.
Abuild works for all changed boards on khepri.
Myles writes:
I've tested serengeti for the failover portion and s2892 for the
nofailover portion.  ldoptions are exactly the same and they both boot
the same.
Signed-off-by: Carl-Daniel Hailfinger <c-d.hailfinger.devel.2006@gmx.net>
Acked-by: Myles Watson <mylesgw@gmail.com>
Acked-by: Peter Stuge <peter@stuge.se>
Acked-by: Uwe Hermann <uwe@hermann-uwe.de>
Changed paths
Path Details
Directorytrunk/coreboot-v2/src/mainboard/a-trend/atc-6220/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/a-trend/atc-6240/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/abit/be6-ii_v2_0/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/advantech/pcm-5820/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/amd/db800/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/amd/dbm690t/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/amd/norwich/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/amd/pistachio/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/amd/rumba/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/amd/serengeti_cheetah/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/amd/serengeti_cheetah_fam10/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/artecgroup/dbe61/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asi/mb_5blgp/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asi/mb_5blmp/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asus/a8n_e/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asus/a8v-e_se/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asus/mew-am/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asus/mew-vm/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asus/p2b/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asus/p2b-d/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asus/p2b-ds/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asus/p2b-f/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/asus/p3b-f/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/axus/tc320/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/azza/pt-6ibd/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/bcom/winnet100/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/bcom/winnetp680/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/biostar/m6tba/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/broadcom/blast/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/compaq/deskpro_en_sff_p600/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/digitallogic/adl855pc/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/digitallogic/msm800sev/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/eaglelion/5bcm/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/gigabyte/ga-6bxc/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/gigabyte/ga_2761gxdk/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/gigabyte/m57sli/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/ibm/e325/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/ibm/e326/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/iei/nova4899r/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/iei/pcisa-lx-800-r10/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/iwill/dk8_htx/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/iwill/dk8s2/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/iwill/dk8x/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/jetway/j7f24/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/lippert/frontrunner/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/lippert/roadrunner-lx/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/lippert/spacerunner-lx/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/msi/ms6119/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/msi/ms6147/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/msi/ms6178/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/msi/ms7135/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/msi/ms7260/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/msi/ms9185/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/msi/ms9282/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/nec/powermate2000/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/newisys/khepri/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/nvidia/l1_2pvv/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/olpc/btest/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/olpc/rev_a/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/pcengines/alix1c/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/rca/rm4100/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/sunw/ultra40/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/supermicro/h8dme/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/supermicro/h8dmr/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/technexion/tim8690/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/televideo/tc7020/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/thomson/ip1000/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s1846/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2735/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2850/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2875/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2880/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2881/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2882/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2885/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2891/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2892/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2895/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2912/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s2912_fam10/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s4880/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/tyan/s4882/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/via/epia/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/via/epia-cn/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/via/epia-m/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/via/pc2500e/Config.lb modified , text changed
Directorytrunk/coreboot-v2/src/mainboard/via/vt8454c/Config.lb modified , text changed
Stefan Reinauer">Stefan Reinauer
ViewVC Help
Powered by ViewVC 1.1.15
