/[Development]
ViewVC logotype
Revision 406
Jump to revision: Previous Next
Author: ebiederm
Date: Tue Nov 13 03:43:37 2001 UTC (11 years, 7 months ago)
Changed paths: 82
Log Message:
- Delayed commit of code for the ASUS A7M motherboard
- VIA 686 cleanups from the A7M code (it now works in a different pci slot).
- Update of assembly printing routines to use the debug levels:
  TTYS0_TX_CHAR now becomes CONSOLE_<LEVEL>_TX_CHAR.
  It's more verbose but now the controls are the same as with the C code.
- Break off of loglevel.h from printk.h.  loglevel.h is safe for both
  the assembly routines and the C code to include.
- Next round of commits for the supermicro p4dc6
- SMP setup updates (Rons board is broken)
  I now allow the other SMP processors to report their existence.
  I really need to add a minimum time to run but that hasn't happened yet.
- SMP per motherboard table of apicids, as the assumption that they
  would always be 0 & 1 with only two cpus fails.
- RDRAM setup updates.  The code isn't done but it now works on more
  than one board at a time.
- More cacheram work.  Minor bug fixes and some macros to use it from C.
- Entry point changes so we no longer have to jump over our gdt.
- Added/Audited the cpufixup for the i786
- IDE intialization for the 82801 ich2 chip.
Changed paths
Path Details
Directorytrunk/LinuxBIOSv1/Documentation/Config modified , text changed
Directorytrunk/LinuxBIOSv1/romimages/RON_VIA_SPD/crt0.S modified , text changed
Directorytrunk/LinuxBIOSv1/romimages/RON_VT5259A/crt0.S modified , text changed
Directorytrunk/LinuxBIOSv1/romimages/RON_VT5426/crt0.S modified , text changed
Directorytrunk/LinuxBIOSv1/src/arch/i386/config/crt0.base modified , text changed
Directorytrunk/LinuxBIOSv1/src/arch/i386/config/ldscript.base modified , text changed
Directorytrunk/LinuxBIOSv1/src/arch/i386/include/arch/cache_ram.h added
Directorytrunk/LinuxBIOSv1/src/arch/i386/include/arch/smp/mpspec.h modified , text changed
Directorytrunk/LinuxBIOSv1/src/arch/i386/lib/console.inc added
Directorytrunk/LinuxBIOSv1/src/arch/i386/lib/cpu_reset.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/arch/i386/lib/hardwaremain.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/arch/i386/smp/mpspec.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/arch/i386/smp/start_stop.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/cpu/i386/entry16.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/cpu/i786/cache_ram_init.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/cpu/i786/cache_ram_start.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/cpu/p6/mtrr.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/include/cpu/cpufixup.h modified , text changed
Directorytrunk/LinuxBIOSv1/src/include/cpu/l2_cache.h modified , text changed
Directorytrunk/LinuxBIOSv1/src/include/cpu/p6/apic.h modified , text changed
Directorytrunk/LinuxBIOSv1/src/include/loglevel.h added
Directorytrunk/LinuxBIOSv1/src/include/pci_ids.h modified , text changed
Directorytrunk/LinuxBIOSv1/src/include/printk.h modified , text changed
Directorytrunk/LinuxBIOSv1/src/include/smp/start_stop.h modified , text changed
Directorytrunk/LinuxBIOSv1/src/include/southbridge/ added
Directorytrunk/LinuxBIOSv1/src/include/southbridge/intel/ added
Directorytrunk/LinuxBIOSv1/src/include/southbridge/intel/82801.h added
Directorytrunk/LinuxBIOSv1/src/mainboard/asus/a7m/ added
Directorytrunk/LinuxBIOSv1/src/mainboard/asus/a7m/Config added
Directorytrunk/LinuxBIOSv1/src/mainboard/asus/a7m/do_ramtest.inc added
Directorytrunk/LinuxBIOSv1/src/mainboard/asus/a7m/mainboard.c added
Directorytrunk/LinuxBIOSv1/src/mainboard/asus/a7m/mainboard_raminit.inc added
Directorytrunk/LinuxBIOSv1/src/mainboard/asus/a7m/smbus.inc added
Directorytrunk/LinuxBIOSv1/src/mainboard/asus/cua/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/dell/350/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/gigabit/ga-6bxc/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/gigabit/ga-6bxc/crt0.S modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/gigabit/ga-6oxe/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/intel/l440bx/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/intel/l440bx/crt0.S modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/intel/l440gx/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/intel/l440gx/crt0.S modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/intel/l440gx/mainboard.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/irobot/proto1/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/lanner/em-370/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/leadtek/winfast6300/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/matsonic/ms7308e/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/pcchips/m754lmr/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/pcchips/m810lmr/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/rcn/dc1100s/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/sis/540/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/supermicro/p4dc6/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/supermicro/p4dc6/cacheramtest.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/supermicro/p4dc6/mainboard.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/supermicro/p4dc6/mtrr_values.c added
Directorytrunk/LinuxBIOSv1/src/mainboard/technoland/sbc710/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/tyan/guiness/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/tyan/guiness/mainboard.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/tyan/s1834/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/tyan/s1834/crt0.S modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/tyan/s1846/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/tyan/s1846/crt0.S modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/via/vt5292/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/mainboard/via/vt5426/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/northbridge/amd/amd76x/raminit.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/northbridge/intel/82815ep/raminit.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/northbridge/intel/82860/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/northbridge/intel/82860/northbridge.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/northbridge/intel/82860/reset_test.inc added
Directorytrunk/LinuxBIOSv1/src/pc80/serial.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/ram/ramtest.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/sdram/generic_dump_spd.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/sdram/generic_sdram.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/sdram/generic_sdram_enable.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/sdram/generic_zero_ecc_sdram.inc modified , text changed
Directorytrunk/LinuxBIOSv1/src/southbridge/intel/82801/82801.h modified , text changed
Directorytrunk/LinuxBIOSv1/src/southbridge/intel/82801/Config modified , text changed
Directorytrunk/LinuxBIOSv1/src/southbridge/intel/82801/ich2_ide.c added
Directorytrunk/LinuxBIOSv1/src/southbridge/intel/82801/ich2_ioapic.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/southbridge/intel/82801/ich2_lpc.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/southbridge/via/vt82c686/southbridge.c modified , text changed
Directorytrunk/LinuxBIOSv1/src/superio/winbond/w83627hf/setup_serial.inc modified , text changed
Stefan Reinauer">Stefan Reinauer
ViewVC Help
Powered by ViewVC 1.1.15
