/[Development]
ViewVC logotype
Revision 4261
Jump to revision: Previous Next
Author: rminnich
Date: Fri May 8 19:23:00 2009 UTC (4 years ago)
Changed paths: 4
Log Message:
I have made a very simple mod to cbfstool that is compatible with the
src/lib/ code in coreboot. I.e. the tool changes but the coreboot code
does not.
Currently, as cbfstool manages the ROM, there are files and empty
space. To allocate files, the code does, first, a walk of the headers
and, if that fails, does a brute-force search of the rest of the
space.
We all agree that the brute-force search has lots of problems from a
performance and correctness standpoint.
I've made a slight change. Instead of an "empty space" area with no
valid headers, I've made a header for the empty space.
So cbfs creation looks like this:
- set up the boot block
- create a file, of type CBFS_COMPONENT_NULL, that contains the empty
space. CBFS_COMPONENT_NULL was already defined in cbfs.h
Here's an example:
[rminnich@xcpu2 cbfstool]$ ./cbfstool testcbfs create 1048576 2048
(cbfstool) E: Unable to open (null): Bad address
[rminnich@xcpu2 cbfstool]$ ./cbfstool testcbfs print
testcbfs: 1024 kB, bootblocksize 2048, romsize 1048576, offset 0x0
Alignment: 16 bytes
Name                           Offset     Type         Size
                              0x0        0xffffffff   1046456
So how do we create a new file?
It's easy: walk the files and find a file of type CBFS_COMPONENT_NULL,
which is as large
or larger than the file you are trying to create. Then you use that file.
- if the file is the same size as the NULL file, then it's easy: take it
- if the file is smaller than the NULL file, you split the NULL file
into two parts.
note that this works in the base case: the base case is that the whole
storage is CBFS_COMPONENT_NULL.
Here's an example of adding a file.
[rminnich@xcpu2 cbfstool]$ ./cbfstool testcbfs add-stage testfixed t
Alignment: 16 bytes
t                              0x0        stage        23176
                              0x5ab0     0xffffffff   1023240
Note that the NULL split and got smaller. But the entire ROM is still
contained by the two files. To walk this entire rom will require two
FLASH accesses.
Add another file:
[rminnich@xcpu2 cbfstool]$ ./cbfstool testcbfs add-stage testfixed tt
Alignment: 16 bytes
t                              0x0        stage        23176
tt                             0x5ab0     stage        23176
                              0xb560     0xffffffff   1000024
So, taking current ROMs as an example, I can reduce FLASH accesses for
cbfs from (potentially) thousands to (typically) less than 10.
Index: fs.c
Changes for readability and cleanliness. Move common blobs of code to functions.
New function: rom_alloc,which allocates files by finding NULL files and using/splitting.
Other changes as needed to support this usage.
Index: util.c
Creating a cbfs archive now requires creation of a NULL file covering the file system space.
Index: cbfs.h
Add a DELETED file type with value 0. Any file can be marked deleted by zero its type; this is a
FLASH-friendly definition for all known FLASH types.
Signed-off-by: Ronald G. Minnich <rminnich@gmail.com>
I think it is a step in the right direction.  Could you add the
function prototype to cbfstool.h?
Acked-by: Myles Watson <mylesgw@gmail.com>
(I added the prototype)
Changed paths
Path Details
Directorytrunk/coreboot-v2/util/cbfstool/cbfs.h modified , text changed
Directorytrunk/coreboot-v2/util/cbfstool/cbfstool.h modified , text changed
Directorytrunk/coreboot-v2/util/cbfstool/fs.c modified , text changed
Directorytrunk/coreboot-v2/util/cbfstool/util.c modified , text changed
Stefan Reinauer">Stefan Reinauer
ViewVC Help
Powered by ViewVC 1.1.15
